fpiehler
#1 Posted : Wednesday, December 30, 2009 11:30:21 AM(UTC)
fpiehler
Ice is clumping in ice maker. Lots of frost in the freezer. I emtied the whole thing out, replaced bucket, let is sit for 4 hours and them turned he icemaker back on. After 2 days the ice is clumping again. Coils were full of dust, so I cleaned them - still happens though. There was some noise from the fan in the freezer a while ago, but that's gone. Noise was like a fan rubbing on something. Freezer and fridge do get cold - I upped the freezer from (5) to a little colder (7) anyway. Still happens. Seals are good - sheet of paper holds in when the door is closed - have to pull it out. Tried not to open the door - to not let room heat in - no luck.
mikem40
#2 Posted : Thursday, January 7, 2010 8:37:00 AM(UTC)
mikem40
Have same problem with frost in freezer. Have you found a solution? Thanks. Mike
mikem40
#3 Posted : Thursday, January 7, 2010 8:38:46 AM(UTC)
mikem40
I have the same problem with frost in the freezer. Have you found a solution?? Thanks. Mike M.
