2 Pages<12
qzymfl
#11 Posted : Tuesday, December 29, 2009 6:01:14 PM(UTC)
qzymfl
I got the clutch off . I am preparing to open the gear case. what should I be looking for and is the gear case fill with oil. If it is what type of oil do I fill it up with? I am in the home stretch
MesaGuy
#12 Posted : Tuesday, December 29, 2009 9:15:54 PM(UTC)
MesaGuy
After you remove the C-clip, you also need to remove the retaining ring, which is the small paper-clip thinkness wire ring hanging out under the ridge in the transmission pinion bearing at the top of the transmission. One end of the wire disappears into a small hole in the clutch base plate.
To get it to release, you might want your wife as a third hand. Use two or three screw drivers. With one screwdriver at the "free" end of the wire (just short of it, between the two pinion bearing protrusions nearest the end of the free end of the retaining ring- push it toward the center rod, and up slightly. With a second screw-driver, push the ring toward the center rod at the next gap between next two protrusions. The wire needs to be worked to the middle (into a tighter circle) and out from under the ridges in the pinion bearing. It will then pop out. Once it does release, then you can just lift the clutch off the transmission rod, as it will be free of the pinion bearing.
qzymfl
#13 Posted : Wednesday, December 30, 2009 3:44:50 AM(UTC)
qzymfl
The response I received from Mesaguy was great... I have removed the clutch..I got the clutch off . I am preparing to open the gear case. what should I be looking for. Worn part, or do I replace everything thats associated with the Neutral drain. What type of oil do I fill it up with? I am in the home stretch
sidfink43
#14 Posted : Wednesday, December 30, 2009 4:40:20 AM(UTC)
sidfink43
I do not rebuild the transmission, I replace it so I cannot really advise you here except to say that replacing it is what I would recommend if you feel it is the problem. Try just replacing the clutch first.
hunterand
#15 Posted : Sunday, January 8, 2012 3:55:13 PM(UTC)
hunterand
I had the same problem on an older model GE top loader. It ended up being the tube to the level sensor switch. It was partially clogged and the machine wouldn't go into the spin cycle because the sensor was telling it there was still water in the drum. I was able to take mine loose and blow through it to remove the clog. Total cost: $0.
Guest
#16 Posted : Sunday, October 16, 2022 4:27:47 PM(UTC)
Guest
Rank: Guest
Groups:
United States
On estate washer top loader have replaced clutch and motor coupler still won't spin. I can here it but just drains water but clothes still dripping
Edited by user Sunday, October 16, 2022 4:30:25 PM(UTC)  | Reason: Not specified
Guest (5)
Kenmore 80 washer agitates but does not spin or drain but timer completes cycles (Washer Repair)
by dmdlargo 6/8/2015 6:50:26 AM(UTC)
Kenmore 70 series washer agitates but does not spin (Washer Repair)
by tismichael 11/16/2013 2:02:16 PM(UTC)
Kenmore washer agitates but does not spin or drain (Washer Repair)
by j-a-z 6/28/2012 11:52:08 AM(UTC)
2 Pages<12
