Black
#1 Posted : Tuesday, December 29, 2009 5:30:31 PM(UTC)
Black
When checking the thermal cut-off if it reads an open is it faulty. The unit will not heat and when i plug the unit in and jumper the thermal cut-off the heating element will come on. And i have no repair manual just shooting from the hip. Thermostats reads 2 ohms (closed) and element reads 10 ohms (closed) and thermal fuse is closed. Blower works well and the exhaust line is not plugged.
Black
#2 Posted : Wednesday, December 30, 2009 11:10:04 AM(UTC)
Black
any ideas Thanks
hvac_hillbilly
#3 Posted : Wednesday, December 30, 2009 11:14:33 AM(UTC)
hvac_hillbilly
if dryer is cool and the thermal cut off (limit switch) is open then it is falty there shoud be a number to tell at what temp it opens should be an inexpensive part replace it
