themalones1995@gmail.com
#1 Posted : 15 years ago
Whirlpool dbl oven Mod#RBD305PDB15 (4 yrs old) Periodically sounds tones, then stops working except interior light, oven comes back on (with tones) within a few minutes to several days,w/ code E6 F2 on display, then works fine.
Needs new Control panel assy? P/N AP3131744, if so, need proper procedure to remove old panel assembly w/membrane...
Could it be Electronic control circuit? P/N AP3598617
Or Sensor? AP4321511
Or Thermostat(TOD)? P/N AP3885687
or Transformer? P/N AP3968801,
Or Electronic clock control board? P/N AP3595759,
Or Thermal Fuse? P/N AP33249... What's your best guess?, (two are not in stock on this website, by the way.;electronic clock control board,electronic control circuit) Thanks.
#2 Posted : 15 years ago
Most likely the problem is a bad control panel. Less likely, but still possible - a bad control board. You can find some useful information in one of our previous threads: http://forum.appliancepartspros...ol-fault-code-e6-f2.html
If any part is shown on this site as out of stock, you can always talk to their team and they will give you the ETA.
zz6938
#3 Posted : 14 years ago
zz6938
Model number : rbd305pdb15
Hi Gene,
I saw your other posts and apllied the trouble shooting steps.
Problem:
Oven sometimes display error code E6 F2.
After displaying this error , i was able to reset it by pressing upper off button.
I could start preheating the oven but in few minutes it shuts down.
On the other hand, it is like, Oven has its own mind...
Display most of the time is blank. Just black out basically. This occurs when there is no error code on the display.
In this condition Oven lights can come on and off, but when i press on start button the result is:
sequential 1 short beep 1 long beep and 3 short beeps
So far what i did today is:
1 I removed the Control panel
2 unplugged the keyboard flat wire
3 plugged back the control panel again without plugging the keyboard flat wire.
the result is:
I turned the breaker back on, While i was walking from the garage to kitchen, i hear the usual beep sound and when i came back i saw oven display is still blank (black).
about 45 seconds later i heard the
sequential 1 short beep 1 long beep and 3 short beeps and the display is still blank (black).
it has been 30 minutes,
No response or beep when pressing buttons on the the control except the light is turning on, when door is open.
What do you suggest?
Thanks in advance for your reply
