Michael Robinson
#1 Posted : Tuesday, December 29, 2009 10:10:31 AM(UTC)
Michael Robinson
The gas stove on my magic chef oven is not igniting. the ignitor seems to be glowing and when I bang the stove with my hand it seems to ignite the flame. Is the ignitor defective> thanks for the advice.
Mike Robinson
#2 Posted : Tuesday, December 29, 2009 11:53:07 AM(UTC)
Measure the current drawn by the igniter. If it's 3.2 amps or less, replace the oven igniter.
- The oven igniter Part number: AP4012072
Michael Robinson
#3 Posted : Tuesday, December 29, 2009 12:46:51 PM(UTC)
Michael Robinson
thanks Gene,
Using a volt meter can i measure the draw by removing the ceramic wire nuts and contacting one wire with each probe?
Thanks Mike R
#4 Posted : Tuesday, December 29, 2009 1:09:31 PM(UTC)
Yes, you can if it has an amperage scale. The meter probes should have a good, reliable connection for at least a minute.
