I have a Maytag washer Model # MAV5057AWW. The washer is about 8 years old. When running on the delicate cycle the machine sometimes finishes the cycle without draining or spinning the water out. At first it only happened once and a while and on the second rinse cycle. Now it happens every time we use the second rinse and is begining to happen on the regular delicate cycle also. Do I need to replace the timer or is it a switch or do I have to buy a new washer I can't afford? Thanks, Rick
