I noticed my food was getting warmer each day. Tonite we noticed frost all over back wall of inside of freezer. We unplugged it and are defrosting it. My bf is doing it and he can test stuff if he knows where it is and what he is looking for. He can fix almost anything LOL. First it was my furnace then microwave and now this LOL does a girl ever get a break any help would be appreciated
Remove the freezer back panel and defrost the coils, should be 100 % frozen, if not tell us the frost pattern. Remove the defrost heater and check to see if it is broken. If so, order it here.Part #AP4355467
Originally Posted by: richappy Remove the freezer back panel and defrost the coils, should be 100 % frozen, if not tell us the frost pattern. Remove the defrost heater and check to see if it is broken. If so, order it here.Part #AP4355467 Thanks Rich when we get that part out will it be visible to the eye if its broken? Not to sound silly but how do I tell if its broken? Should I look for a physical break? hole or crack?
It will be black and you will see an open area inside the glass cover.
