I have an older kenmore electric oven, it throws a code F5 when turning on oven, stove top burners work fine. If I lean gainst the door it sometomes works, I am guessing I need to adjust the door contact but have no idea where this is. I pulled the oven out from the wall but see no model number plate. Thanks
Model # is 911.9368810 Thanks
