taz2tweety
#1 Posted : Thursday, December 24, 2009 2:22:20 PM(UTC)
taz2tweety
the refrigerator's compressor will come on and run for about 1 min. and then shuts down. will kick back on after a little while then run 1 min. and then kick out. any idea's?
#2 Posted : Friday, December 25, 2009 5:10:11 AM(UTC)
Could not find info using the given model number. The following tech sheet is for a GS2SHAXKB01.
Replacement parts for gs2shakb01 models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%202216656.pdf
Could be a number of things.
First check that the compressor fan is running
If OK
Unplug the unit and check the overload and relay
Also check the compressor windings with a meter.
Be sure to also check them to the case/ground also(all should be infinite ohms).
If all OK
Try running it without the capacitor.
Here are a couple good sites with help on troubleshooting
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Refrigerator troubles (Refrigerator & Freezer Repair)
by rosto 7/29/2008 9:17:59 AM(UTC)
