Our GE dishwasher cycle start handle gets stuck when you try to go around the cycle to start the dishwasher , it stops at the plate warmer/heated dry and will not move. I removed the door interior cover and nothing looks broken or damaged. Both the detergent and the timer levers look ok. when I put it back together it worked fine. It seems to get stuck when the detergent cover is not locked in place. Any suggestions on what to do to repair this problem? Thanks and Happy Holidays Dad the fix it guy:)
