Changed first board, it burned, then new water solenoid, micro sw., flapper solenoid(burned 1st time thought that was the problem) then control board burned again. I saw water near board on plastic. I figure water is hitting board and taking it out. Ice maker works and auger spins. Any other ideas before I stop using ice? It blew out transistor And a couple of other things. These boards are expensive, need help!
The only thing I can tell you is that there could be a split in the water hose. Or the hose is to far in, and is splashing on the board. Pull the hose and see if you could bring it out farther. I have done that before and it worked. Tom ApplianceEducator.com
Originally Posted by: kayakcrzy  The only thing I can tell you is that there could be a split in the water hose. Or the hose is to far in, and is splashing on the board. Pull the hose and see if you could bring it out farther. I have done that before and it worked. Tom ApplianceEducator.com will give that a try, another board I guess. Have you ever rebuilt a board?
