foreverNalways5609
#1 Posted : Wednesday, December 23, 2009 12:27:22 PM(UTC)
foreverNalways5609
ok so my dryer wasnt turning... the belt was slipping so i took it apart and looked at it.. i need a new belt. I thought i put it all back together and i didnt and it sparked... so i unplugged it and put it back to together. After that i forgot to put in the screws holding the door on and i went to open it and it sparked again. the wire right above the door is what sparked.. Do you think that i fried a wire? and if soo how much would i take to replace? :(
#2 Posted : Thursday, December 24, 2009 1:16:49 AM(UTC)
Sounds like problem with the wires going to the door switch.
You will have to open it up and check.
Depends on how much damage was done.
There is a possibility that you will not have to replace any thing.
If the problem is not just a loose wire )re: the switch is wired incorrectly) a Model Number may help find a wiring diagram to ensure you rewire it correctly.
