I have a ge profile washer. Starts, fills, agitates fine. Then stops mid cycle. A push pull on the control and it will start and run for awhile, only to stop again. What could be the problem? Suggested solution? New part? (number?) Thx. Mark
Hi mark I have the same problem with a G.E washer. It sounded to me like a bad timer but turns out it does the same thing with a new one installed. I also jumped out the lid switch with no success. I would appreciate it if you would let me know if you find a solution to the problem . Thanx lcn96
Well I can coax mine through the cycle with a little on and off. My brother and I tested the water level switch, and since that was ok I ordered a new timer. I hope I haven't wasted my money. If the new timer does not fix the washer, then I'll call the GE repairman to finish the job.
Mark
