theopinto
#1 Posted : Monday, December 21, 2009 7:17:32 AM(UTC)
theopinto
Hi I have a side by side Daewoo fridge. the frezeer seems to be ok but the fridge is warm, opened the back panel and the fun is not running. do you know what could be causing this.
#2 Posted : Tuesday, December 22, 2009 6:54:48 AM(UTC)
I cannot find any info on this unit so the following is just general info.
If the evaporator coils are not ice/frosted up solid it could be your only problem is the fan and it is not pushing cold air into the fresh food section.
Normally the voltage required by the fan is on it's label. Many are 120 volts AC.
Check to see if you have voltage at the fan.
If yes and the fan does not run replace it.
Fridge not cooling down checked the fun not running (Refrigerator & Freezer Repair)
by theopinto 12/21/2009 7:16:59 AM(UTC)
