paularae johnson
#1 Posted : Friday, December 18, 2009 8:48:08 AM(UTC)
paularae johnson
I'm lost.... we have a roper dryer h.duty large capacity model and the past 3 weeks we have been fighting with the thermostat for high limit heat blowing.. we have check all the wiring and cleaned out the vents and blower chambers.. all is clean and there is no air restrictions. the heatiing coils are in great shape and heat if we put the two wires together to check.. but after a load or two ( med load) the thermostat blows again... any suggestions... this is getting old...
sidfink43
#2 Posted : Sunday, December 20, 2009 6:37:54 AM(UTC)
sidfink43
Check the heating element again to make certain it is not grounding to the frame somehow, and change out the operating thermostat. I am guessing that the operating thermostat is not shutting off, causing the heating element to reach the temperature that causes your high limit to blow.
