fitzdp
#1 Posted : Monday, December 14, 2009 9:26:21 PM(UTC)
fitzdp
Help,
Wife called and stated that our 2.5 yr old dryer quick working. I checked it out and it has an ERROR code of F2 on it.
What does this mean and is it easy to fix. I am fairly handy so replacing parts is not an issue for me, however troubleshooting this equipment is.
Appreicate any help that I can get.
Thanks!
Dan
#2 Posted : Tuesday, December 15, 2009 4:12:09 AM(UTC)
This should help you trouble shoot
http://www.servicematters.com/d...heet%20-%20W10035270.pdf
If you can confirm it is a keypad problem you may wanbt to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
fitzdp
#3 Posted : Friday, December 18, 2009 3:59:08 PM(UTC)
fitzdp
THanks for your help. I acutally have replaced the USER INTERFACE BOard and Cable but still getting an F 2 errors on the dryer
I am at a loss for what the F 2 Error means. It have ruled out the User INterface board---what else could it be??
Thanks!
Dan
#4 Posted : Sunday, December 20, 2009 5:46:11 AM(UTC)
I cannot find just an F2 error anywhere.
All I can suggest is that you go through the tests in the tech sheet.
Perhaps someone else will jump in who has seen this error.
