AppliancePartsPros.com
Appliance Repair Help
Washer Repair
affinity frididaire side loader turns off at last spin
I have a front loader a little over a year it goes through the whole wash and at the last spin it turns off :confused:
First check your warranty and see if any of the components, particularly the electrical boards are still in warranty. Then contact Frigidaire and see if they will provide any warranty service since you are just out of warranty. Not likely, but worth a try. You then need to see if you can put the machine in test mode and retrieve error codes which will help diagnose your problem. Here is the service manual which will show you how. A bad wire between the speed control board and main control can be the problem, along with problems in the speed or main boards. http://frigidaireservicetips.co...AffinityWasherManual.pdf[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ATF6700FS1"][/URL]
The warrany expired on October. Thank you for the manuel. I have done some the test and came back with an E 41 error where do I go from there? Also where do I go to get the PTC what is this? Originally Posted by: sidfink43 First check your warranty and see if any of the components, particularly the electrical boards are still in warranty. Then contact Frigidaire and see if they will provide any warranty service since you are just out of warranty. Not likely, but worth a try. You then need to see if you can put the machine in test mode and retrieve error codes which will help diagnose your problem. Here is the service manual which will show you how. A bad wire between the speed control board and main control can be the problem, along with problems in the speed or main boards. http://frigidaireservicetips.co...AffinityWasherManual.pdf
Washer Repair
