paularae johnson
#1 Posted : Friday, December 18, 2009 11:23:27 AM(UTC)
paularae johnson
how do you check a blower housing/working thermostat with 4 termianals.. two heavy wires on end and 2 light wires in center...
#2 Posted : Friday, December 18, 2009 3:19:11 PM(UTC)
Section replacement parts for WHIRLPOOL REL4434AW0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%203396197.pdf
The 2 heavy red are the contacts, should be 0 ohms at room temperature.
The other 2 are the internal heater, should be approximately 7,000 ohms.
paularae johnson
#3 Posted : Saturday, December 19, 2009 4:37:55 AM(UTC)
paularae johnson
thanks for your help... it varified what we found... appreciate the information...
