melaniebabson
#1 Posted : Thursday, February 28, 2008 2:36:08 PM(UTC)
melaniebabson
My washer is making a noise when it is agitating, not a thump or a grind but more like a surge (brief) and the lights in the area are affected.
What would cause this?:confused: Seems to happen as cycle is advancing.
Still works but without interruption but want to find out why and what is needed to fix.
Thank you,
#2 Posted : Friday, February 29, 2008 11:09:47 AM(UTC)
The cause of this could be: the timer, the motor or the wiring. Try to pinpoint the noise and post your findings.
Here are the break down diagrams for the Whirlpool washer Model LA7800XPW0
#3 Posted : Friday, February 29, 2008 11:28:48 AM(UTC)
I would pull off your pump and motor and turn the transmission coupler counter clockwise and check for internal transmission problems like jamming at different positions of rotation.
#4 Posted : Friday, February 29, 2008 12:09:41 PM(UTC)
This is a good tip for a direct drive washer.
I believe the washer we are talking about is a belt driven model.
#5 Posted : Saturday, March 1, 2008 6:25:19 AM(UTC)
Uh, sorry, wrong washer type. It also could be a wire shorting on the control magnet housing, the two solenoid item attached to the tranny.
