C Cole
#1 Posted : Thursday, December 17, 2009 4:21:53 PM(UTC)
C Cole
Dishwasher making loud noise. Found broken glass in bottom, removed pieces. Still noisy. How do I disassemble beyond the nut on the lower spray arm?
#2 Posted : Saturday, December 19, 2009 1:50:53 AM(UTC)
I could not find info on the given model number.
Please check it.
The following is for a GU980SCGZO which I think yours probably is.
Here are the parts
Pump and motor replacement parts for WHIRLPOOL GU980SCGZ0 | AppliancePartsPros.com
Here is a tech sheet and a manual which should be helpful.
http://www.servicematters.com/d...0Sheet%20-%208066008.pdf
https://secured.whirlpoo...510938/$FILE/4322430.pdf
Bosch dishwasher loud noise under (Dishwasher Repair)
by harless1 1/16/2011 7:33:08 AM(UTC)
GE Triton dishwasher loud noise after draining (Dishwasher Repair)
by fkong186 10/20/2009 1:04:47 PM(UTC)
