katie123
#1 Posted : Thursday, December 17, 2009 11:59:04 AM(UTC)
katie123
Hi, my Frigidaire dryer FEZ831AS1 squeaks really loud and high-pitched every time I run it. The squeak starts and stops at random. What parts should I consider changing? Thanks for your help!
#2 Posted : Thursday, December 17, 2009 3:02:59 PM(UTC)
Most likely the problem is a bad rear bearing (#12 on the diagram). You also may want to check the front felts (#23 & #24) and the front glides (#20).
- The rear bearing kit Part number: AP2142648
