donaldearl
#1 Posted : Wednesday, December 16, 2009 2:35:23 PM(UTC)
donaldearl
My harness switch went bad so I replaced the switch with(GEH WB18T0339) and the spark module (4+0) with (GEH WB13T00339). Sometime the sparks work but not all time. Everything wAS WORKING PERFECTLY until the wiring harness switch burn't up. I turn one knob and sometimes it sparks and sometimes it does't. One of the others will spark and one not at all.
#2 Posted : Wednesday, December 16, 2009 5:10:57 PM(UTC)
Check all wires and connections. Check all burner igniters. Make sure all ignition switches are pushed all the way down on the burner valves.
The part numbers you posted are incorrect.
donaldearl
#3 Posted : Thursday, December 17, 2009 9:21:02 AM(UTC)
donaldearl
Thanks for your reply GENE. The #'s that i posted was right off the order form. anyway i firgued it out & my cooktop is noe working perfectly thanks again for your help. DON
#4 Posted : Monday, December 21, 2009 5:12:45 PM(UTC)
You are welcome, Don.
Happy Holidays!
