2 Pages<12
elacesar
#11 Posted : Wednesday, December 16, 2009 2:08:01 PM(UTC)
elacesar
Thanks again rich for your quick help.. Sounds good because you are bypassing the timer to make sure that the compressor is good right? I will try this in the morning of course with my fingers crossed cause the wifey is getting frustrated and I dont have the money for a costly repair job..
elacesar
#12 Posted : Thursday, December 17, 2009 7:36:25 AM(UTC)
elacesar
Hello Rich i am back with bad news for me cause the wire jumping did not do anything at all.. The lights turn on as usual but no compressor.. Just to let you know that the fridge is in my garage and it is about 35 to 40 degrees if that means anything..but i would believe that it should at least spin the fan..Sorry to be a pest and thanks alot..
#13 Posted : Thursday, December 17, 2009 12:18:16 PM(UTC)
Try a jumper on the cold control, might be bad.
elacesar
#14 Posted : Thursday, December 17, 2009 12:32:11 PM(UTC)
elacesar
Okay sounds good..
elacesar
#15 Posted : Friday, December 18, 2009 6:44:45 AM(UTC)
elacesar
Hello rich i think i found the culprit when i jumped the cold control it started up right away.. I am rushing to get the part right now and hopefully this is the only problem.. Thanks again to you and everyones help....Merry Christmas
2 Pages<12
