AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Ge Profile Fridge, lights blinking, thaed out, no ice & no water.
A few weeks ago it said it needed a new water filter. hadnt had time to change it ... the water stopped and the ice stopped.
Looked at it a few days ago, took the filter off put it back on and reset the light.
Noticed today everything thawed out, the lights and numbers to adjust the temp are just kin dof blinking and not really on?
any thoughts?
Dont laugh...
Home depot is saying it may be stuck in demo mode. Is there a way or how do you get it out. I tried un-pluggin it for 15 mins but no changes...
So I held all 4 panel buttons down then adjusted frezzer to 0 and food/fridge to 7. I also put on a new water filter.
The lights ar enot blinking no more. But, I dont htink I can hear the motor running.
When I turn the ice maker button on and off it does purge with water. The water is not workling yet either.
The hrs light did blink a few tims as well in between mee setting the temp #'s...
Other googled sites say stuff like this for different or slightly similar models...
"HRS means the main board on the back has detected an internal short. HR means the defrost heaters are not working so if you are getting HR check the back of your freezer for excess frost.
If it's HRS then replace the board on the back of the unit.
Here is the part you need. The part is located behind a 6 X 10" sheet metal panel on the back of the unit--- very easy to replace, just plug and play."
Did the new board solve the problem?
Never put a new board in ... just saw that as what others were doing. I felt like maybe I had messed the programming up somehow and maybe that was the issue.
I was just throwing out there whatever I could to try and help those who know more pin point the problem.
Thanks,
J
I saw the question below somewhere and it is very similar to what mine is doing. "Our GE Artica Frig, model # PSS26SGRC has decided to have a nervous breakdown. The ice and quick ice lights are pulsing. We can not dispense ice or water. The control readout on the frig side is flashing "hrs" and will not accept input. I tried to " reboot " by unplugging for 20 minutes, thinking pleasant thoughts and plugging back into the outlet. No change. Any ideas?" The guru's solution was : "Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00." Sorry I am going into depth with this ... it's just right now I'm the typical sob story and it's a bad time of year. I am trying to fix this for my Mom and th emoney just isnt there right now. But if this is the problem I know I have to bite the bullet. Just making sure I don't have any alternatives. Thanks for all your help and time.
Would the dispenser light dim when you press the water dispenser lever? If Yes, then the main control board on the back of the refrigerator has gone bad. - The main control board Part number: AP4436216
