rsquires
#1 Posted : Monday, December 14, 2009 3:12:34 PM(UTC)
rsquires
I have no control of the temp. It freezes everything. the temp control will turn it of but not control temp. Any suggestions?
#2 Posted : Tuesday, December 15, 2009 2:40:31 AM(UTC)
If you want help, measure and post the back freezer wall temperature.
#3 Posted : Tuesday, December 15, 2009 3:43:04 AM(UTC)
I am assuming you are talking about the fresh food section.
The freezer temp should be close to degrees F.
Here is the tech sheet/wiring diagram
http://manuals.frigidaire.com/p...f/Anderson/240389609.pdf
And a couple manuals which should also be useful
http://frigidaireservicetips.com/pdfs/396_6.pdf
http://frigidaireservicetips.com/pdfs/495_2.pdf
Note: the second one has the best info on the air damper see Page 17.
It could be the damper which regulates the air flow from the freezer into the fresh food side is not closing.
rsquires
#4 Posted : Tuesday, December 15, 2009 11:39:03 AM(UTC)
rsquires
Yes. I should have said the fresh food side
