tkeemm
#1 Posted : Wednesday, February 27, 2008 6:37:29 AM(UTC)
tkeemm
my kenmore gas dryer will start up and heat up for about three minutes. then it will try to heat up again but the ignitor just starts up but there is no flame. Does anyone have any sugestions?
#2 Posted : Wednesday, February 27, 2008 4:10:14 PM(UTC)
Most likely the problem with your dryer are a bad coils on the gas valve.
- The part number for the kit of the gas valve coils is AP2150379
tkeemm
#3 Posted : Thursday, February 28, 2008 5:48:04 AM(UTC)
tkeemm
thank you i will try to replace the coil. is it pretty easy to do? Do I need to take out the whole gas assembly?
#4 Posted : Thursday, February 28, 2008 9:41:21 AM(UTC)
In order to provide more accurate advise I need the complete model number of the dryer.
tkeemm
#5 Posted : Thursday, February 28, 2008 9:57:20 AM(UTC)
tkeemm
the model number is Kenmore, 11087878100 and the serial number is M90508095
#6 Posted : Thursday, February 28, 2008 10:16:56 AM(UTC)
Just remove the bottom panel.
You need a short Phillips screwdriver to remove the two screws holding the bracket on top of the coils.
dennisdaubenspeck
#7 Posted : Thursday, February 28, 2008 10:39:41 AM(UTC)
dennisdaubenspeck
dryer not going through cycle on auto dry timmer not adv workes on other cycles mod #tgdx640jqo
#8 Posted : Thursday, February 28, 2008 10:46:31 AM(UTC)
Did it get hot?
For more accurate advise I need more specific description of the problem.
Guest (6)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by liz777 1/6/2011 9:11:35 PM(UTC)
by kamputty 4/11/2010 8:40:39 PM(UTC)
by pauleouellette 3/10/2009 12:37:59 PM(UTC)
by bseibes 8/28/2008 6:59:14 PM(UTC)
dryer does not heat up (Dryer Repair)
by dralonso 2/21/2008 10:52:52 AM(UTC)
