on2mars
#1 Posted : Saturday, December 5, 2009 6:21:49 PM(UTC)
on2mars
I need some help with a Uline combo 75FF undercounter refrigerator /
icemaker. The icemaker at best only trickles water into the ice bucket. I
have changed out the solenoid valve controlling the water flow to no avail.
The previous valve did not allow any flow to the icemaker. The unit gets
sufficiently cold to make ice. The unit was making ice prior to transport
for one location to another.
Any advice would help. Should I consider purchasing a new valve for
controlling the icemaker?
wisconsin_tech
#2 Posted : Monday, December 14, 2009 1:57:01 PM(UTC)
wisconsin_tech
Call 800-779-2547 with your model and serial number. They should be able to help you.
This could be many things such as a low water pressure supply to the valve (do you have an RO system upstream from the icemaker) or maybe the fill tube right before the icemaker is frozen. The best way to fix this is to leave it off and door open until it thaws out. Adding heat could do some damage to the interior.
try U-Line Service - Welcome to U-LINE Service for more info.
