viz
#1 Posted : Monday, December 14, 2009 5:40:59 AM(UTC)
viz
Broiler not heating, display says it is on. Bake ok. Checked continuity of broiler element~16ohms. Have 230v across contacts of broil relay when broil selected. Relay contacts obviously not closing.Suspect bad relay board?
#2 Posted : Monday, December 14, 2009 10:42:49 AM(UTC)
That would also be my guess.
I cannot find a wiring diagram for this unit so cannot be of much use here.
Would be nice to confirm it. If you measure a voltage across the relay coil and it does not close then you know for sure that it is toast. I am not sure what that voltage should be. Could be that the relay coil has opened which would be an easier check.
Or perhaps you can hear the relay close, then you would know that it's contacts are shot.
Depending on which board is gone it may be difficult to find a replacement.
viz
#3 Posted : Monday, December 14, 2009 11:15:23 AM(UTC)
viz
It's kinda hard to get in there and check the voltage to the coil with power on, I'll try later. You're right, board is no longer available. One company said they still may be able to get it
#4 Posted : Monday, December 14, 2009 12:02:23 PM(UTC)
There are companies out there that will repair boards.
I have never used one so cannot recommend one to you.
Also I do not know what they charge.
Just Google "oven timer control board repair"
Oven and Broiler not working (Oven Repair (including Ranges and Cooktops))
by Broncojo 5/22/2015 4:03:12 PM(UTC)
Tappan oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by mrthtolan@yahoo.com 10/15/2014 6:44:08 AM(UTC)
oven and broiler not working, need part (Oven Repair (including Ranges and Cooktops))
by Todd F 9/24/2014 6:16:39 PM(UTC)
Frigidaire Oven broiler not working (Oven Repair (including Ranges and Cooktops))
by isitjustme 8/28/2014 12:43:06 PM(UTC)
Tappan TEF326FBA Oven & Broiler Not Working (Oven Repair (including Ranges and Cooktops))
by jgorrz 1/9/2014 5:46:17 PM(UTC)
Upper oven broiler not working (Oven Repair (including Ranges and Cooktops))
by Johnswales@bellsouth.net 12/14/2013 6:12:51 AM(UTC)
Older GE oven broiler not working (Oven Repair (including Ranges and Cooktops))
by rabatvilla 3/7/2013 5:08:51 PM(UTC)
Kenmore oven & broiler not working (Oven Repair (including Ranges and Cooktops))
by jennyl6873 1/18/2013 6:59:38 AM(UTC)
Accubake Broiler Not Working (Oven Repair (including Ranges and Cooktops))
by husky300 12/17/2012 10:16:57 AM(UTC)
Top Broiler not working (Oven Repair (including Ranges and Cooktops))
by mbrangers84 12/8/2012 7:43:59 AM(UTC)
Jenn Air upper broiler not working (Oven Repair (including Ranges and Cooktops))
by fgo2 8/14/2012 2:29:10 PM(UTC)
by Cody Moss 6/18/2012 7:32:59 PM(UTC)
Oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by boomer913 3/14/2012 1:13:25 PM(UTC)
by boomer913 3/14/2012 1:00:22 PM(UTC)
oven abd broiler not working (Oven Repair (including Ranges and Cooktops))
by Dianedeon123 12/22/2011 10:22:50 PM(UTC)
