2 Pages12>
rexicon
#1 Posted : Sunday, December 13, 2009 7:26:42 PM(UTC)
rexicon
gu1500xtks0 was in the middle of a quick wash cycle when it simply stopped. Checked the breaker - fine. Checked that there is current coming into the machine and there is.
No lights anywhere on the control panel.
To complicate matters this machine has had issues with the control panel 2 yrs ago. The normal cycle would not work or light up. I replaced the control panel - it ran ok for a couple of days but then reverted back to the same problem so I just put the old one back in and have been doing the quick cycle ever since.
Could this be the electronic control assembly rather than the control panel this time?
Thanks, Rex
nobleelectronics
#2 Posted : Sunday, December 13, 2009 10:44:07 PM(UTC)
nobleelectronics
i would do a test on the thermal fuse as feisty63 said, usually when this model is completely dead the thermal fuse is bad Part number: AP3178588
is what your looking for
a continuity test should determine if its good or not
#3 Posted : Monday, December 14, 2009 5:03:02 AM(UTC)
Replacement parts for WHIRLPOOL GU1500XTKS0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208530866.pdf
This may also come in handy, if not now perhaps in the future
https://secured.whirlpoo...520548/$FILE/8178022.pdf
Most likely culprit is the thermal fuse, Item 6/2.
If it is blown be sure to use the new harness as this is an update for random fuse blows.
Next would be the door switch.
Also could be a broken wire from the line cord connection point to the control board.
Then it may be either the control board or keypad.
Since you have to open it up you might as well try to fix this.
You will see the pin-outs for the keypad in the tech sheet.
You will also see that certain pins/tracks are used for more than one key so if a number of keys do not work this will narrow it down for you and you can check the circuit trail from that pin on the board to see if it has a crack or a bad solder joint,
Does sound like only the one key is shot but you may not have noticed that the others do not work.
That it worked for a couple days suggests a dirty connector.
Try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
rexicon
#4 Posted : Monday, December 14, 2009 7:20:05 AM(UTC)
rexicon
OK - so far so good. Fuse is dead. Will replace and report back.
Thanks for all the help so far.
rexicon
#5 Posted : Monday, December 14, 2009 3:25:35 PM(UTC)
rexicon
It's alive!! - well all except the normal cycle which even after scrubbing with toothbrushes and alchohol didn't come back to life unfortunately. I wonder if a new ribbon cable might do the trick?
Nonetheless I'm happy to dodge the $700 bullet for a $20 part!
#6 Posted : Tuesday, December 15, 2009 12:41:25 AM(UTC)
No I do not think it will make a difference, You already replaced the Control Panel (keypad) and have cleaned the connectors so the most probable culprit would be the control board itself.
rexicon
#7 Posted : Tuesday, December 15, 2009 5:20:05 AM(UTC)
rexicon
Not sure if I'm going to bother checking this or not. At this point I'm just glad to have it back in action. The last thing I want to lash out on at Xmas is a new dishwasher and w/2 young kids there's no way to do without.
Having used it now for 2 years - I can tell you that the Quick Wash cycle actually does a half decent job as long as you don't load it to the gills and has the advantage of being quick/economical.
Do any of the online vendors accept returns on control boards?
Daniel J
#8 Posted : Tuesday, December 15, 2009 8:54:21 AM(UTC)
Daniel J
I have the exact same problem with a KitchenAid KUDI01. Where is the thermal fuse located?
#9 Posted : Tuesday, December 15, 2009 9:10:52 AM(UTC)
rexicon
Here is the operators manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203381184.pdf
Looks like Pots and Pans is pretty close to Normal so I would use it if the dishes are not quite clean
Daniel J
Please start your own thread in this section using Post New Topic.
Adding to this one will just confuse things especially if yours is a more complicated fix.
Also your Model Number is short about 5 digits.
rexicon
#10 Posted : Tuesday, December 15, 2009 9:54:32 AM(UTC)
rexicon
Denman - good to know - thank you all very much for your help!!
Saved me some serious grief and $$$
Guest (8)
2 Pages12>
