dupontjams
#1 Posted : Wednesday, February 27, 2008 4:06:03 PM(UTC)
dupontjams
is my Heater sub-assembly bad if it is reading no ohms i've check mythermal fuses and their good still not heating up
#2 Posted : Thursday, February 28, 2008 12:16:30 PM(UTC)
If the reading shows "∞" Ohms then the heater is bad and has to be replaced. In that case you, probably, can see the broken heating coil too.
- The part number for the heating sub-assembly is AP3988748
Here are the break down diagrams for the Magic Chef dryer Model LDE7304ACM
Heater sub-assembly (Dryer Repair)
by dupontjams 2/27/2008 4:09:09 PM(UTC)
