billhds
#1 Posted : 15 years ago
billhds
When the unit defrosts, instead of the water collecting in the evaporation drain pan located outside the food compartment, it trickles down the back of the housing and winds up under the crispers. The problem has been solved in the past by removing the food and turning off the unit for 12hrs. or so.
I looked at the parts schematics but could find no drain tube that outlets to the pan. Where in the heck is the water coming from, and how does it get to the drain pan? The unit has been off for 16 hrs. now and I'd like to make sure that nothing is clogged or broken before starting it back up.
#2 Posted : 15 years ago
The water is from the defrosting of the coils in the freezer.
Usually it runs down a tube on the back of the fridge.
There are 2 ways that it can get into the tube. I cannot tell which yours uses by looking at the parts diagrams.
1. Directly from the freezer out the back.
2. It drips into a funnel like part at the top back of the fresh food and then out the back to the tube.
First I would check at the bottom end/drip tray to be sure it is not clogged here with dust etc.
If OK
Then you will have to blow it clean from the top.
A compressor on low pressure works, using a straw and blowing into it works depending if you can get a decent seal or a turkey baster and somer warm water.
Once clear it is a good idea to flush it withla 10% bleach solution here is where the baster is really handy. This will kill/flush out the crud growing in it. Just watch that you do not overfill the drip tray.
While you are messing with it you might as well clean the condenser coils and fan blade under the unit.
billhds
#3 Posted : 15 years ago
billhds
Yes, the attachment at the top rear of the refrigerator compartment is where the extra water comes from. However, there are also some little icicles hanging down from the opening of that attachment. If you turn the unit off for 12 + hours and everything thaws, the problem doesn't recur for better than a year. Thoughts?
#4 Posted : 15 years ago
I have seen it suggested but have never tried the following.
To keep the drain from freezing take a piece of bare copper 12 gauge wire and wrap it around the defrost heater once or twice and then down the drain an inch or so.
The idea is that every defrost cycle the wire will also defrost the drain.
Cannot see why it would not work and have seen people who seem to know their fridges pretty well suggest it.
Only concern I would have is the wire getting too hot during defrost.
billhds
#5 Posted : 15 years ago
billhds
Sounds good to me. Over and out.
Bill
KitchenAid drain tube frozen solid (Refrigerator & Freezer Repair)
by jonathan.howes@gmail.com 2 years ago
Heater Wire: drain tube heaters and door rim heater assembly (Refrigerator & Freezer Repair)
by OzarkMcCoy 5 years ago
Drain Tube replacement part? (Refrigerator & Freezer Repair)
by RPMerg 11 years ago
Drain Tube (Refrigerator & Freezer Repair)
by jnovak64@hotmail.com 11 years ago
Freezer dripping into fridge, Can't get to drain tube check valve?? (Refrigerator & Freezer Repair)
by g20zoom 11 years ago
clogged drain tube (Refrigerator & Freezer Repair)
by tommy cochran 13 years ago
drain tube freezeing up (Refrigerator & Freezer Repair)
by ccpccart 14 years ago
Drain Tube Access (Refrigerator & Freezer Repair)
by Afishh 15 years ago
Drain tube clogged (Refrigerator & Freezer Repair)
by dojo55 15 years ago
Where is the drain tube/water freezing bottom of freezer (Refrigerator & Freezer Repair)
by GertieMae3 15 years ago
Where is GE refrigerator freezer drain tube (Refrigerator & Freezer Repair)
by mastone3 15 years ago
Amana top freezer how do you get to the drain tube (Refrigerator & Freezer Repair)
by jdmyers19024 15 years ago
Kenmore fridge leaks water into fridge instead the drain tube (Refrigerator & Freezer Repair)
by skg 16 years ago
Drain Tube Help (Refrigerator & Freezer Repair)
by crappieman 16 years ago
Installing Amana drain tube freeze up kit (Refrigerator & Freezer Repair)
by jwkriz 16 years ago
