Please help...
I put a new drum in. But for some reason when I wrapped the belt around after putting it in, it's not tight. I see what it should be wrapped around (white plastic wheel, small metal golden wheel, etc) but it still has a lot of slack. Please help...wife is gonna kick me out if I don't get this fixed.
THIS FORUM IS DEAD!!!!!!! |
Thanks....appreciate the prompt reply. But I don't see my dryer. I have a front load maytag/neptune. Any advice?
Thanks. Based on this, I am hooking the belt back up correctly....around the white wheel and the motor, correct?
But I still have a LOT of slack. When I put it all back together the drum didn't turn unless I lifted the belt up. I think I might have stretched the belt out when I took the old drum off...dang it.....
Ideas/thoughts?
