joserafael
#1 Posted : Friday, December 11, 2009 1:19:00 PM(UTC)
joserafael
I can't see anything clot it out side of the screen. I don't know how to removed the screen to see inside. A little bit of water stay inside the Dishwasher. Any suggestion? :( :confused: :mad:
WHIRPOOL DU800SWKUO FL 3121637
TYPE 280-0
#2 Posted : Saturday, December 12, 2009 2:11:25 AM(UTC)
Replacement parts for DU800SWKUO models | AppliancePartsPros.com
Here is a service manual for a DU800 series, yours should be close.
https://secured.whirlpoo...510938/$FILE/4322430.pdf
First check your drain line and house pluming for a partial plug.
One area that can be a problem is where the drain hose goes over the fitting into the house plumbing.
If OK then I would take the pump apart.
