This freezer does not cool at all, but fan runs and the freezer clicks and hums loudly for several seconds periodically and then stops humming. What to do next?:confused: :confused:
You may want to replace the start relay and overload for the compressor. If it would not help, the compressor has to be replaced.
If you need the correct part numbers, post the end of the model number.
