a friend gave me this fridge worked good at his place took home worked 3 days then it stoped i have lights in fridge but the control panel has nothing any ideas what might of happend
If the fridge is completely dead and does not make any noises - most likely the problem is a bad main control board.
Unfortunately the part is no longer available.
Originally Posted by: Gene If the fridge is completely dead and does not make any noises - most likely the problem is a bad main control board.
Gene. searsdirectparts.com has parts for my kenmore mfg 3/95
Originally Posted by: Mkendall searsdirectparts.com has parts for my kenmore mfg 3/95 My Bad it is Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears Parts Direct | SearsPartsDirect.com from Sears they do have almost all parts for mine including main board and all controls.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
You can get kenmore parts from AppliancePartsPros as well, for less in most cases. After all, Sears is just a department store, they don't actually manufacture appliances or parts. Unfortunately, socasml's board has been discontinued and is no longer available.
