The icemaker quit working. the waterdispenser in the door still works, but I don't think the ice maker is getting water
Make sure the water feeding tube into the ice maker is not frozen. Locate the water inlet valve on the back of the refrigerator. Swap the wires between the ice maker and the water dispenser solenoids. Push the water dispenser lever for a few seconds, open the freezer door and check if there is water in the ice maker. Post the results. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED2FHEXTT01 Refrigerator | AppliancePartsPros.comGene.
