The bottom element is sagging btwn the supports and touching the oven shell, is this dangerous, effect efficeincy, need to be replaced, can add'l supports be added, other?
thanks!
I would replace it.
If it shorts to the oven case it may well destroy your control board. |
THIS FORUM IS DEAD!!!!!!! |
