AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
The lid and machine is HOT but inside the drum is NOT
I just acquired this used dryer. Exchanged cord from my old dryer. Turned it on and the outside of the dryer got hot to the touch. The clothes inside the drum stayed wet and cold. Could I have hooked up the wires wrong??
When you turned it on did the drum spin?
If drum spins
Remove it from the vent, is there air flow (exhausting)? |
THIS FORUM IS DEAD!!!!!!! |
the drum turned; but no heat inside the drum
Definitely try what denman said and remove the vent from the back and then turn it on and let us know if it is pushing a lot of air through the vent. if so, is it cold air or warm air coming out?
Dryer Repair
