bigbro
#1 Posted : 15 years ago
bigbro
my microwave handle has cracked off. i am waiting for the replacement handle and want to be ready to fix once i get it. i have looked at the door and cant find any screws to remove to see what has to be done. when it cracked off there is plastic still inside two holes. how do i get behind to remove and re-install the new door?? thanks
applianceman
#2 Posted : 15 years ago
applianceman
This page should help GE Spacesaver Microwave Handle Replacement
Once you access the screws you can hold the plastic with needle nose pliers and turn the screw out.
ElaineMowery
#3 Posted : 15 years ago
ElaineMowery
My handle broke at the top and bottom clips that holds it into the door. I can not see the screws but think the page posted will help. My question is, will the new handle come with the clips that need to be replaced in the door or do I need to order another part?
