Ok i read this forum for a week and with some testing came to the conclusion that my dishwasher that shows no sign of life had a bad control panel. i know the thermal fuse is good i tested it and then had it tested. Im getting power through the door switches and they test good. Installed a new control panel today and the same thing nothing no power to the control panel. no lights at all. So now im guessing that it has to be the control board now. i bought the panel through this website and read that if i did so i could return it with in thirty days. i have orderd a new control board tonight and hope that this will fix my problem. All i want is the dishwasher to work. Is there another test that im missing. OR another part that could be doing this. Was i right on the return policy and if the board comes and that dosen't fix the problem what else could it be ?
is there no answer or help for this ?
Temporarily bypass the thermal fuse with a wire and see if it works, if not you may have a bad door switch.
Thanks for the replies but both of you should have read the original post that i wrote . Thanks anyways i fixed it it was the internal themal resistor located in back of the unit.
