Tara G
#1 Posted : Wednesday, December 9, 2009 12:58:53 PM(UTC)
Tara G
I tried to start my dryer last week and it made a pulsing quiet buzzing noise. I have since torn the entire thing apart, searched extensively on the web and concluded that it was most likely that the motor had gone out. I ordered a new motor and blower which arrived today.
I have installed the new motor/blower, reconnected all wiring (except for the interior light) and just tried to start it. Hoping to hoot, holler, and celebrate, I was extremely frustrated when it only made the same exact sound as before. Is there something else I need to reassemble before it will work? Or did I just buy a new motor/blower for nothing? Any ideas on what else it could be?
Thank you!
#2 Posted : Wednesday, December 9, 2009 4:18:02 PM(UTC)
There are two parts I would check: the broken belt switch (#5 on the diagram) and the thermal fuse (#59 on the diagram).
- The broken belt switch Part number: AP3094230
- The thermal fuse Part number: AP3133489
Here is the wiring sheet.
Tara G
#3 Posted : Wednesday, December 9, 2009 4:42:16 PM(UTC)
Tara G
Thank you Gene.
How would I go about 'checking' these? Should I be checking continuity?
#4 Posted : Wednesday, December 9, 2009 4:51:42 PM(UTC)
Quote:
... Should I be checking continuity?...
Yes, that's right.
TheDragon
#5 Posted : Wednesday, December 9, 2009 5:09:23 PM(UTC)
TheDragon
try to turn the end of cycle signal knob to silent
and/or try to make sure the timer is full off (make it click)
I had the same sound - thought it was bad wires arching in the outlet
then thought it was bad wires in the electric control panel
then tracked the sound (using a home made stethoscope)
to the little speaker that emits the end of cycle beep/buzzer
even that was the 'source' of the sound - still not sure what the cause was
I replaced the circuit board because I lost my heat -
fixed the sound - still trying to fix the no heat
Tara G
#6 Posted : Friday, December 11, 2009 5:37:45 AM(UTC)
Tara G
thank you for the advice. I have been without a dryer for near three weeks now and finally broke down and took it to the repair shop. I ran out of clean socks a few days ago :( I asked them to call me and they said I could be present while they work on it. Hopefully I will get a lesson along with my bill.
Thanks!
