2 Pages<12
jeclose
#11 Posted : Sunday, December 6, 2009 6:29:06 PM(UTC)
jeclose
Thanks for getting back.
This float switch has only two terminals - but two wires to one terminal, and one wire to the other.
I went ahead and ordered a new float switch anyway (from here - the prices are much better than ************************.com). I scheduled GE appliance repair to come out next Friday to look at it, but if the part gets here first, I'll install it and see if it does the job. Like you said, this switch MAY be okay - and maybe it IS the control board - notwithstanding that it is new.
LIke I said, there was no resistance when the switch was open (OL) - not depressed.
So you think that means it's okay?
I think there is additional tech info on the inside of the door; if I get a chance, I'll take the door apart. It has to be taken apart anyway if the Control Board is the issue.
Let me know if you have any more brainstorms on this - much appreciated.
Originally Posted by: applianceman Go to Quoted Post
Ok I was looking a wiring diagram for a similar model that had three terminals on the float switch and I though yours did as well. If this is the case disconnecting the wires will not have any effect on the C4 code.
What you did with the ohmmeter proves the switch is ok as long as the numbers you got were close to zero and if you disconnected the wires before testing. Other wise you can get a false reading.
As far as I know the only thing that has anything to do with this are the float switch and the control. I realize the control is new and I can’t say for sure if it is the problem or not. But then again I was looking a diagram that showed three terminals on the float switch.
The switch on the solenoid isn’t the problem it will cause the C2 code rather than the C4.
Look for the mini manual under the dishwasher and see if it says anything about the C4 code and if so post what it says.
jeclose
#12 Posted : Monday, December 7, 2009 7:14:06 AM(UTC)
jeclose
I went ahead and ordered the float switch... if it doesn't work, then we'll know that isn't the problem, and if your theory is correct, then it is likely a bad control board. So I've scheduled GE Appliance Repair to come out this Friday and have a look at it. At least I will have done 90% of the diagnostic work at that point :)
Thanks for your help, ApplianceMan, and if you have any more ideas, please feel free to post them here.
Oh - I read that article on using an Ohmmeter - very timely. I'll go back and do that measurement again, armed with some knowledge this time.
applianceman
#13 Posted : Monday, December 7, 2009 8:09:22 AM(UTC)
applianceman
Good may he will find something we are missing, like I said originally I was looking at wiring diagram which obviously not the correct one. Not to mention that control is probably expensive.
With the float up the meter should read OL and with the float down it should be close to 0 like .25 or something like that.
jeclose
#14 Posted : Tuesday, December 8, 2009 6:27:34 PM(UTC)
jeclose
Okay - I removed the door, and found the technical instructions for various error codes posted there. There are two suggestions there that I found that were not already done: One is to check and see if the water flow is more than 10 seconds longer than it is supposed to be - cause that means it's out of spec. If it is, it says something like "replace the control". Yeah - what control?
The other suggestion is to check the "wire harness". Since I had the door off, I did check as many connections as I could, including those to the control board (I even removed the control board cover to get at it and examine it). They all seemed okay.
I also checked the resistance on the float switch again. It is reading OL when open, and puts up numbers when I depress the switch. I'm assuming that means it's okay, although I did order a new switch a couple of days ago.
Any thoughts?
applianceman
#15 Posted : Tuesday, December 8, 2009 7:45:04 PM(UTC)
applianceman
Did it say how long water should flow? Were you able to check how long water did flow?
What you are saying tells me the float switch is ok but do you know what the number the meter says when the switch is closed. I know it goes up and down (I hate digital meters) but do you know the approximate number.
jeclose
#16 Posted : Sunday, December 20, 2009 8:31:17 AM(UTC)
jeclose
Here's an update on this still-untractable problem:
On Dec. 11th, GE Appliance Service came out and spend some quality time diagnosing the problem. After checking everything from the float switch to the wiring cable harness, the tech thought that he had found the magic solution - it all seemed so simple: He said, "Just touch the "start" button and the "clear/reset" button at the same time." It seemed to work. I thought, "Wow - that was easy - why didn't I think of that?" Indeed, the technician guidelines posted on the inside of the door seemed to suggest just that.
But not so fast. The day after the tech visit, I ran the dishwasher in the rinse/hold mode late in the evening - no problem. But sometime during the night, I woke up and heard the dishwasher beeping - several hours later. I got up and took a look at it - and, sure enough, there it was beeping the C4 error once again.
I touched the "start" and "clear/reset" button - but nothing happened. Turned off the power, turned it back on, and did the same thing - still nothing. And that is where it stands - it is still delivering the same message.
Now, the inside of the door sticker (it's not a "mini-manual - just a sticker with info for the repair tech) suggests several solutions, including replacing the inlet water valve - which I have done. The float switch was also replaced when the tech was here.
It also suggests checking the wiring harness, which the tech also did. The only suggestion that has not been followed up on is this: It states that if the water fill time if 10 seconds longer than spec, that the control (control board?) may need to be replaced. The tech did not check that to the best of my knowledge.
I called GE appliance repair again, and they told me over the phone (in addition to scheduling another visit on Jan. 8th) that there could be a check valve issue. He said there is a check valve coming off the drain side of the pump, and said this was, to the best of his recollection, in the right rear of the machine. This was also suggested to me by someone else, as follows: "We would suspect a check value issue and water is seeping back into the sump and triggering the overfill fault".
So this looks like the next avenue to explore. But two questions: Just where is THIS check valve? Is the tech right - it comes off the pump in the middle of the machine? Looking under there, I see the drain solenoid assembly, and the motor, but not seeing a hose coming off off that pump/motor thing. Is it visible from the back of the machine, and accessible from there? Is he referring to the thing that the plunger assembly threads into, below the filter screen in the rear of the dishwasher? I have a picture of this, and it looks like there is a check valve gasket there, but I would have to access it from the rear of the dishwasher, or pull the dishwasher out of its enclosure, which would be a herculean task (for reasons I won't go into here).
Can you verify that this is the check valve that this is being referred to by both the tech and the other person who provided me advice?
Any other thoughts - such as, would the C4 error with the machine suddenly beeping a code in the middle of the night be consistent with a failed check valve?
applianceman
#17 Posted : Monday, December 21, 2009 5:22:20 AM(UTC)
applianceman
There is a check valve in the drain hose outlet. I have a hard time thinking this is your problem being that the code is coming up even if there is no water in the tub if I understand you correctly. But it is very inexpensive and worth trying. Water can come in from the sink if the sink were clogged a little. This is why you should have a high loop in the drain hose. In other words the drain hose should run up above the bottom of the sink before connecting to the drain. You will probably have to remove the dishwasher to access the check valve.
jeclose
#18 Posted : Monday, December 21, 2009 5:28:50 PM(UTC)
jeclose
Hey, Appliance Man -
I did find the check valve, but not before cutting a large hole in the cabinet panel directly behind the dishwasher, based on the advice I got from the GE appliance service tech :mad: So add the costs of having my cabinetry guy make a replacement panel to the $400 or so I have already spent on this dishwasher since last summer (the bulk of that was an earlier visit to replace the control board).
So after cutting away a large hole in the back cabinet so I could reach the putative location of the check valve, I found that there was no check valve there. In fact, on this machine, it is in the front - easily accessible. I guess I could have checked the dishwasher body schematic, but I decided to trust what I was being told over the phone. So, chagrined, I removed the hose from the check valve, unthreaded it and removed it, and - voila! - found the little rubber gasket with a flapper - the check valve! I was told to look and see if it was distorted or otherwise. Indeed, it is - the flapper part is intact, but it is sitting in a kind of open position.
Now how would that cause a C4 error? I don't really know. I'm just putting blind trust into advise given me by people who supposedly know more than I do on the subject. Maybe it is misplaced. In any case, I went online and found that this outfit doesn't carry the check valve anymore, so I had to source it elsewhere. Also, you can't just buy the 20 cent rubber check valve part - you have to buy the whole check valve. So add another $20 to my bill. It will arrive around Jan. 5th, and the technician is scheduled to visit on January 8th. Maybe there is some magic connection here between the check valve and the C4 error - I can only hope, even if it doesn't seem to make sense.
Any further thoughts? You should know that the dishwasher DOES have a high loop in the drain - I ascertained that while doing the check valve. If it's not the check valve, could it possibly be that I have a bad control board - notwithstanding that it was replaced only a few months ago?
applianceman
#19 Posted : Tuesday, December 22, 2009 2:50:39 PM(UTC)
applianceman
I hope it is repaired now!! It would be odd to me if this were causing the code because I was under the impression that there was no water in the washer when the code came up. Water shouldn’t back into the dishwasher from the sink if you have a high loop unless water is backing up to the point that it fills the sink. It would be interesting if the flap repairs your problem so keep us posted.
Sorry for the mishap with you cabinets, I am not sure why they would suggest that! Most of the time dishwashers are not hard to remove from the cabinet. So even if you couldn’t access the flap I would have suggested removing the dishwasher. He may be a good repairman but I wouldn’t want him cutting on my cabinets to access a part on my dishwasher! That would be like saying cut a whole in the outside wall to access the compressor on a refrigerator.
None of this is directed at you I just don’t know why he suggested such a thing.
jeclose
#20 Posted : Wednesday, December 23, 2009 5:38:11 AM(UTC)
jeclose
Just to clarify - the GE appliance guy didn't suggest I cut a hole in the back panel behind the dishwasher - he only said that he thought the check valve was somewhere in the back of the dishwasher, so I took it upon myself to cut the hole to access it, rather than try to pull out the dishwasher, which seemed like the lesser of two evils. The reason is because the front of the dishwasher has been tiled in, and I would probably have to break and/or cut tile to get it out, so until I know the dishwasher is dead and not repairable, I'm not going to do that. So blame me (largely) for destroying my cabinetry, albeit I did get bad advice on that point.
Your point is well-taken: "I was under the impression that there was no water in the washer when the code came up." That is correct. There is no water in the tub when the code is flashing. But at this point, I am grasping at straws, and it seemed worthwhile to give the check valve theory a try. It that doesn't work, I'm going to have to suspect the control board, notwithstanding that it was replaced back in July/August. It may be a bad board. Your thoughts?
Guest (4)
2 Pages<12
