paulcoovert
#1 Posted : Tuesday, December 8, 2009 3:15:38 PM(UTC)
paulcoovert
I recently order a Panel-con (6K2104 part no. WPL 6-919765), order Number 926634, for a Jenn-Air dishwasher. I've removed the screws holding the old panel except for 2 Fastener panel screws (part no. AP4365077) that may require a special tool to remove and install. If you look at the Panel-Con it has at the top two large opening which it looks like a 90 degree pliers is needed to access the screws. I'm not sure, please advise...:mad:
#2 Posted : Tuesday, December 8, 2009 4:27:04 PM(UTC)
brucelaird
#3 Posted : Sunday, March 13, 2011 11:19:47 AM(UTC)
brucelaird
So, Can you tell me what is the solution to remove the control Panel? Same problem/challenge
Bruce
