troyvb
#1 Posted : Monday, December 7, 2009 9:59:46 AM(UTC)
troyvb
my washer suddenly has stoped performing the wash cycle/action.. times out and goes to rinse cycles.. any ideas??
Thanks!
sidfink43
#2 Posted : Tuesday, December 8, 2009 2:49:48 PM(UTC)
sidfink43
Since the machine preforms all of the agitation and drain and spin activities the problem is probably electrical.
Take off the timer connection and clean the contacts, and check all of the wiring between the motor and the timer.
If this all checks out, consider replacing the timer.
Here is a service manual for your model.
http://www.servicematters.com/m...ary/docs/RS3100005R3.pdf[URL="http://www.servicematters.com/maytag_library/docs/RS3100005R3.pdf"][/URL]
Frigidaire skips wash cycle (Washer Repair)
by lab.lady 12/18/2012 10:15:31 AM(UTC)
Washer skips wash cycle (Washer Repair)
by vicster76 8/30/2012 1:04:09 PM(UTC)
