jeremyh65
#1 Posted : Sunday, February 24, 2008 8:23:41 PM(UTC)
jeremyh65
Actual age is unknown, I bought from craigslist 6 months ago. So, the agitator is not operational. Also, I noticed that my clothes are much too wet at the end of the cycle; are these issues related or independent of each other. Looking for troubleshooting advice. Thank you so much.
#2 Posted : Monday, February 25, 2008 1:56:36 PM(UTC)
In order to provide the most accurate advise I need you to post more specific description of the problem.
jeremyh65
#3 Posted : Tuesday, February 26, 2008 3:19:24 AM(UTC)
jeremyh65
Thanks! Specifically, when a cycle begins the washer will fill up with water,then once full it does nothing for a number of minutes, after which time it will spin and drain. It then refills, and again once full it will do nothing for a number of minutes. Then it repeats the spin and drain. I'm assuming that the periods of "doing nothing" are the times it should be agitating. At completion of the cycle, the clothes are much too soaking wet, and I notice clumps of powdered soap on my clothes. Hope this helps.
#4 Posted : Tuesday, February 26, 2008 10:29:55 AM(UTC)
Did it make any noises while it was "doing nothing"?
jeremyh65
#5 Posted : Tuesday, February 26, 2008 11:48:21 AM(UTC)
jeremyh65
It made no noise while doing nothing.
#6 Posted : Wednesday, February 27, 2008 10:35:30 AM(UTC)
Most likely the problem is a bad timer.
- The part number for the timer is AP3100187
Guest (4)
Kenmore 90 plus series washer won't spin, barely agitates, will drain & makes noise (Washer Repair)
by Maryland Mom 8/21/2012 11:04:52 AM(UTC)
Kenmore 90 plus series washer (Washer Repair)
by eclay 8/11/2009 11:05:29 AM(UTC)
