When I set the temp to 34F the actual temp is like 41F. I have replaced the motorized damper and that did not solve the problem. Should I replace the temp control or is it something else
What is the exact temperature in the freezer?
The temp in the freezer is 0 degrees but the thermostat was at -2 degrees
How is the fan in the freezer works? If there is nothing wrong, I would replace the temperature sensor (#22 on the diagram) first. Gene.
Hello Gene, Thanks for the advice. Can you tell me where the temp sensor is located. I can not tell from the diagram. Phil
Phil,
It should be on a side wall, behind a cover (#23).
Hello Gene, Thanks again for your help. I looked in the freezer and fridge sides and cannot locate the temp sensor. There is nothing that looks like the diagram description. Phil
I have a PSC23NSTDSS serial # RL449436. It's only 3 years old and my wife noticed that the refrigerator side wasn't cooling properly. It is set at 35, but the digital reading says its 49. The freezer is set at 0, but it says its 2. The ice is melting in the ice maker. Please help!
Thanks, Chris
Originally Posted by: buckeyes007  I have a PSC23NSTDSS serial # RL449436. It's only 3 years old and my wife noticed that the refrigerator side wasn't cooling properly. It is set at 35, but the digital reading says its 49. The freezer is set at 0, but it says its 2. The ice is melting in the ice maker. Please help!
Thanks, Chris Answered here: http://forum.appliancepartspros...ot-cooling-properly.htmlGene.
Hello Gene, I can not locate the temp sensor in the refrigerator model number FLSC238DS6
