wjay
#1 Posted : Friday, December 4, 2009 11:24:20 AM(UTC)
wjay
Greetings!
GE Profile Microwave/Convection, over the cooktop.
After reapplying power to kitchen appliances after a brief vacation, the micro will not accept power. (I always throw the breakers to avoid possible surge damage.) The unit worked perfectly the night before I threw the breaker.
Voltage to the receptacle is normal. The oven is dark!
I assume there is an internal fuse. If so, that should be my first test. Can anyone confirm a fuse? Any idea where it is located? Will I have to remove the oven from its perch above the cooktop to troubleshoot?
Thanks in advance!
Jay
wjay
#2 Posted : Monday, December 7, 2009 6:40:22 AM(UTC)
wjay
I have opened up the oven and checked the power input and the obvious fuse. Both were okay.
Can anyone help me with the next steps of troubleshooting?
Thanks again.
GE Profile Convection/Microwave Oven
JVM1790WK01
Less than two years old.
Jay
wjay
#3 Posted : Monday, December 7, 2009 11:43:49 AM(UTC)
wjay
I have since checked all thermal cutoffs. All OK.
Any ideas?
Thanks!
