I have posted three times about a problem with an icemaker, with no response. How long does it usually take to get an answer to a problem? :confused:
It can take forever if no one knows the answer or can at least make an educated guess.
Have you tried searching the forum using the "ADVANCED" search option? |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  It can take forever if no one knows the answer or can at least make an educated guess.
Have you tried searching the forum using the "ADVANCED" search option? Thanks denman for an answer. I looked at the advanced search and found nothing. I guess I'll start replacing parts until I get it fixed. Thanks anyway
