tonyluan
#1 Posted : Wednesday, December 2, 2009 5:54:32 PM(UTC)
tonyluan
Please help does my refrigerator model gss22kgpccc have a defrost timer ?
but i can't fine it if so what part should i buy?
thank you very much!
AIMANNY
#2 Posted : Wednesday, December 2, 2009 9:26:43 PM(UTC)
AIMANNY
230 UserPostedImage
Enlarge Photo
Defrost heater kit - *Note* Redesigned heater kit now uses two heating elements to give a better defrost cycle. It replaces the single element that was used on some models.
Part Number: AP4355467 made by GE
AND
240 UserPostedImage
Enlarge Photo
THERMOSTAT DEF
Part Number: AP3884317 made by GE
#3 Posted : Thursday, December 3, 2009 3:21:12 AM(UTC)
Do the test in my resonse above "help, unit not cooling", most probable problem a bad defrost heater.
tonyluan
#4 Posted : Thursday, December 3, 2009 4:08:24 PM(UTC)
tonyluan
Please help i already order the defrost heater kit and i already install the pink and the blue cable on the right side. What about the left side please help.
#5 Posted : Friday, December 4, 2009 12:58:16 AM(UTC)
The heater comes witht the jumper installed, you should be good to go now.
tonyluan
#6 Posted : Saturday, December 5, 2009 5:19:39 PM(UTC)
tonyluan
Can someone help me please how do i install the Thermostat. I only see that the old wire the organge it connect to the blue wire and the pink connect to the pink wire. Do i have to cut it and rewire the thing but how please help! When i receive the thing it does not have any instruction come with it.
thank you!
#7 Posted : Sunday, December 6, 2009 12:47:41 AM(UTC)
If ypo are replacing the defrost thermostat, just clip the wires off the old one and use insulated but splices to connect up the new wires, polarity not important.
tonyluan
#8 Posted : Sunday, December 6, 2009 8:27:57 AM(UTC)
tonyluan
I lost the nut to connect the wire and i think the pink and blue wire are burn out how do i can get a replacement for my model.
