dtailer
#1 Posted : Wednesday, December 2, 2009 4:51:02 PM(UTC)
dtailer
The 3-positiion Fabric Temp Switch doesnt seem to make a difference in the temp - its always just hot. Is there some way to test this switch, or whatever it gets its information from?
Thanks for all your hard work, it is much appreciated!!
DanF
dtailer
#2 Posted : Friday, December 4, 2009 5:09:51 PM(UTC)
dtailer
Does anyone know anything about the 3 position temperature switch on a Kenmore Dryer?? Does this switch go out by itself? I need help please.
Dtailer
#3 Posted : Saturday, December 5, 2009 1:05:04 AM(UTC)
I cannot find a wiring diagram for this unit so am doing some guessing here.
Check in the units control console for the wiring diagram.
Your unit was manufactured by Whirlpool but I cannot cross reference it.
First unplug the unit and check the heater.
Remove both wires from the heating coil and measure the coil, usually around 10 ohms.
Then measure from each side of the heater to the case, both should be infinite ohms. This tests for a grounded element which can run without control from the thermostats so it is hot all the time.
I think your unit uses a thermostat with 4 prongs.
2 of them are the contacts, the other two are an internal heater. Measure the heater should be around 6,000 ohms.
The way this works is for lower temp settings the unit sends power to this internal heater so that the thermostat is not only getting heat from the main heating coil but also from the internal heater so it turns off more often reducing the units heat output.
Odds are it is one of the above.
Let us know how it goes or if it is not one of the above.
Always a good idea to give the interior a good cleaning, including the blower wheel. I would also clean/check the vent system.
Here is a good site with basic info which you may find useful
http://www.applianceaid.com/dryers.html
dtailer
#4 Posted : Saturday, December 5, 2009 11:19:59 AM(UTC)
dtailer
Denman ---- Thank you so much for your help!! Especially since you are volunteering your time to help so many!!
If there is anything I can ever do for you from the Pacific Northwest, please let me know - I would be so glad to return the favor.
Until then, please know that there is someone counting all these sacrifices you make for total strangers, and building you and yours a mansion for all eternity...
Our Best,
Dan and Ginie
#5 Posted : Saturday, December 5, 2009 2:19:11 PM(UTC)
Thank you for the kind words
You are welcome
I just hope that my earlier post will help you get up and running.
Guest (4)
